1 - 6 of 6 Posts
IMG_0916.JPG this is what I have been finding in my air box. Last week I cleaned it out it was about half full. This pic is only a thousand miles. It seem to be water somehow mixing with crankcase vapors. I changed the oil. No water I the oil. Oil looked good. Any ideas what could be causing this?
no photo. click on paper clip above to download photo.
Tell us what year and model bike is a must.
if its water then you don't have it sealed good. look it over.
Your oil blow by hose you can route down to ground if you so choose to
2006 kingpin with 135,000 miles
YUK!
Yeah get that blowby hose off your airbox, Had a Yam 650 one that had lots of blowby I routed a hose to make a chain oiler.
While it does look bad, I would bet that you are getting condensation in your engine, and it is boiling off into the crankcase vapor line, as intended. Clovis looks to be in a fairly dry area, but in that same desert you can get a bit of water into a frying pan set out overnight (at least sometimes.) Is your bike parked in a closed garage? Is there often dew on the metal in the morning?
It would not take but a CC or two of water to make the oil vapor look that way.
I would not worry about it too much.
Also don't the CA bikes have some sort of additional clean air systems on them? Maybe an EGR? Certainly a vapor canister???
1 - 6 of 6 Posts
