1 - 6 of 6 Posts
Are the Freedom engines from 92 ci - 100 ci - 106 ci, all the same jugs and outer dimensions, just bored out more? Or is each one different?
I don't know about the 92 but I'm pretty sure the 106 is the same as the 100 just with a bigger bore.
I know that when I bought the big bore kit it had to be for a 2003 -2005 model. I don't know about the 2002 model. I do know that there were changes in 06 to the 100CI and up motors.So they are not backwards compatible.
If you start with a 100" engine (102mm stroke), there are bore kits available for 104", 107", or 109".
If you start with a 106" engine (108mm stroke), these same bore kits yield 110", 114", or 116".
1 - 6 of 6 Posts
