Front brake caliper
607 Views 5 Replies 5 Participants Last post by  otab
2008 Kingpin 8 Ball. The 5 mm hex pin is stripped. Can I order the pin only or do I have to buy the entire caliper?
1 - 6 of 6 Posts
Check victoryparts.net.They show them available seperately.
If you buy a factory genuine brake pad kit, the pin is included. The stock Nissin pads aren't the best available, but the replacement pin can be a lifesaver. Assemble with antisieze on the thread, don't overtighten.
Some Kawasaki ones fit (oops, could be wrong here, does the 3008 model have Brembo or Nissin caliper?)
Also, check out the first Recommended Reading thread below., from Otab.
Kawasaki for sure fit the Nissan on cross bikes they use same pin on several designs. Pretty sure Honda Nissan caliper pins are also same but I haven't got with one of my Honda friends to check yet.
Best bet just buy cheap kit that includes a new pin if you can't find it on any parts diagram. Use good pads though. Depending on how much pin itself costs you might come out ahead buying cheap pads and tossing them.
Kawasaki part numbers
Pin 43045-1053
O-ring 43058-1100
or
or
(note that these pins have 3/16 inch allen sockets, not the 5mm socket that the oem pins and the other replacements linked above have)
See less See more
Reactions: 1
1 - 6 of 6 Posts
