1 - 7 of 7 Posts
front master cylinder leaking at the brake lever would replacing the push rod and boot fix this or does it need a new master cylinder
Discussion Starter · #3 ·
Thanks for getting back victory dealer wanted 283.00 Just bought the ness rad III set up of e-bay 250.00
If you have cable clutch set up on the RADIII.....make sure you debur and round off a bit of the upper cable retaining drum (inside where cable end is held for clutch lever). It will eat clutch cable withing 30-40 pulls.
1 - 7 of 7 Posts
