1 - 2 of 2 Posts
ARC AUDIO KS 125.2 BX2 Amplifier - New In Box, never installed.
Product Features:
Designed and engineered in the USA
Compact Class H Non Digital Circuit Design
Designed by Robert Zeff
Compact chassis design for small vehicles and/or motorcycle applications
Can drive highly reactive loads
Custom hand wound output inductors help produce clean reliable power and eliminate unwanted AC ripple while increasing the amplifiers reliability and stability
Hi-Level speaker inputs for OEM integration onto most factory radios
Optically isolated Mosfet power supply
Stable to 2 ohms stereo / 4 ohms mono
Integrated protection against: Reverse Voltage, Over Voltage Speaker Short, and Thermal Overload
ARC Audio BX2 low frequency and bass enhancement technology
Built in Hi-Efficiency quite fan for additional cooling
Bridge mode auto detect (autosense remote turn on)
Auto sense turn on remote out
Integrated external fusing
Specs:
Power @ 4 Ohms 2 Channels x 70 Watts
Power @ 2 Ohms 2 Channels x 125 Watts
Power @ 4 Ohms (Bridged) 1 Channel x 250 Watts
S/N Ratio 101dB
THD .05%
Frequency Response 20Hz - 20kHz
Input Senstivity 170mv - 3.5v
Crossover Butterworth (5Hz - 550Hz) 12dB
BX2 (See Details Below)
Fuse 1 x 30 Amp
Dimensions 8.25"(L) x 4.8"(W) x 1.7"(H)
BX2 is a bass frequency extension technology that provides perceived bass frequency response below the low frequency cut off in an audio system.
BX2 uses the principle of the missing fundamental, which creates the sensation of low frequencies by generating a carefully calculated series of harmonics designed to simulate the auditory experience in the human ear caused by the missing fundamental pitch.
These harmonics extend the perceived frequency response up to 1.5 octaves below the speaker cutoff frequency (f3) without perceived distortion, increased peak power consumption or peak speaker excursion.
BX2 technology allows the system user to experience dramatically improved levels of system performance, sound quality and improved low frequency
response by:
Increasing low frequency output and performance without causing the speakers to perform outside their physical design limitations.
Decreasing power consumption during low frequency reproduction up to 75%.
Allows small format speakers to reproduce low frequencies traditionally designed for
larger speakers.
I have this listed on eBay for $225 with free shipping. Might be willing to compromise just a tad if reasonable offer.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290685036328
Discussion Starter #2
.....sold.....
1 - 2 of 2 Posts
