1 - 14 of 14 Posts
I have a older model of the Rampage Motorcycle lift.
I had it in my Dodge Dakota and my Ford F150.
I have used this to load a Yamaha 950, Vol , Victory XRoads and a HD Road Glide with ease.
It is similar to the below link.
http://www.rampagelift.com/
I am asking $600.00 if your interested.
Man if you weren't so far away I'd be a buyer.
Dan, before you give up there's a bunch of freight companies like Yellow freight, FedEx Freight, LTL, that will move a pallet for a couple hundred bucks.....You'll have to pick it up at the local terminal but if the savings is enough...............
you both could meet halfway in some state
a friend has one and really likes it. Not fast loading but 100% better then him trying to do it
I watched the vids ....How does in [un]load ? The cable can't push it out...:)
Mine has a I/4" piece of Teflon? and rollers that makes it slide real easy.
To unload you let out the cable as you pull back on frame.
Once its out about 3 feet the weight takes over.
Has a 10 foot wired remote control.
You say it is similar to the link you posted, is it a different brand? If so, what brand? Also, how long is it? Can it be mounted in a 6 1/2 foot bed?
Thanks
Thanks
There is a metal tag mounted to it:
Jet Trax
Manufactured By;
R.P.M. Sales, Inc.
P.O. Box 2378
Idaho Falls, ID
(208)525-9200
And yes it can be mounted in a 6 1/2 bed, both my trucks were, but tailgate must be left open as the loader is 8 foot long.
It uses a Warn wench as the power source.
A big hit with the HD crowd I bet!
At the "tipping" point...that's quite a load on the t/gate cables ! I think I'd give them a double check !..........jmo
Do you have any pictures? I have been thinking about one of these for a while now.
1 - 14 of 14 Posts
