1 - 9 of 9 Posts
put in as much as you can new gas. Additives are just snake oil
get the app pure gas now at your finger tips you can have good gas.
Never had any issues using it or not using it but the stuff at Walmart star tron I think it's called has been used by me and friends and never let me down
+1 on replacing with fresh gas. If the gas presently in your tank is more than a month old and does not have a stabilizer in it, the volatility has diminished and won't ignite well. The only thing you want to put into gas is a stabilizer if you're not going to be using that engine for a month or more.
Nothing will fix bad gas. You have to replace it. Stabilizers are good for storing gas but will not fix bad gas. As suggested earlier, get a pump and siphon as much out as you can. But don't mess up your lawnmower by using the bad gas in it.
1 - 9 of 9 Posts
