1 - 3 of 3 Posts
Guys, any help would be appreciated. I have a couple problems, but the first is a slight fuel leak. I just finished installing my Thor pipes and PCV. I did end up taking the tank off, but when I went to prime the fuel pump, I noticed a small leak coming from the fuel line where it connects to the fuel rail. Is this normal till it's primed? I have a '13 Hammer 8 Ball.
The other question I had was about the PCV map. So far those are the only two performance mods I have. Can I get away with the stock map the PCV came with? I've read the M19-002-003.pvm map from dynojet may work ask well.
Any inputs would be appreciated, thanks!
take line off put back on. If its quick connect you should here a click when it snaps in place.
Don't think the PCV will do much for you but write Rylan and the Vic shop he will send you a starting map
1 - 3 of 3 Posts
