1 - 2 of 2 Posts
Hi was wondering went to start the bike 2007 hammer and fuel was coming out under the tank.The fuel line has a crack in it.Does anyone know what size the fuel line is there no size on the hose?Can you just use regular fuel line or do you have get it from dealer as it has a bend in it were it goes to tank.Dealer does not have it go figure.
1 7518086 Screw 3 Usage
2 7517845 Screw 1 Usage
3 ------- ASM., IGNITION SWITCH/FUEL CAP [See Ignition Asm. Page, Ref. 5] 1 Usage
4 1014739-493 Tank, Fuel 1 Usage
4 1014739-1240 Tank, Fuel 1 Usage
4 1014739-266 Tank, Fuel 1 Usage
4 1014739-1232 Tank, Fuel 1 Usage
5 5412414 Cover, Mount, LH 1 Usage
5 5412415 Cover, Mount, RH 1 Usage
6 7517525 Screw 3 Usage
7 5134160 Bushing 3 Usage
8 5412480 Bushing, Flange 6 Usage
9 5412071 O-Ring 2 Usage
10 5133613 Plug 1 Usage
11 7710515 Ring, Retaining 1 Usage
12 5412096 Grommet 1 Usage
13 5412095 Grommet 1 Usage
14 7556193 Washer 1 Usage
15 7556192 Washer 1 Usage
16 7547186 Nut 1 Usage
17 5412332 Hose 1 Usage
18 7081151 Clamp, Hose 4 Usage
19 2520251 Fitting 1 Usage
20 5411869 O-Ring 1 Usage
21 7556131 Washer 1 Usage
22 5412093 Grommet 1 Usage
23 5412094 Grommet 1 Usage
24 5435763 Line Fuel Vent 1 Usage
25 5435764 Line, Water Drain 1 Usage
26 5435771 Line, Water/Fuel To Ground 1 Usage
27 2520322 Asm., Fuel Line, Filter 1 Usage
28 2520733 Asm., Fuel Pump 1 Usage
28 2520678 Thermistor, Fuel Pump [Level Sensor] 1 Usage
29 7547233 U-Nut 1 Usage
30 7556260 Washer, Flat 1 Usage
31 1253363 Asm., Throttle Body 1 Usage
31 5411886 Cap, Fitting 1 Usage
32 5412259 O-Ring 2 Usage
33 1203277 Adapter, Throttle Body 1 Usage
34 7516610 Screw 2 Usage
35 7080511 Clamp, Narrow Band 2 Usage
36 2520207 Asm., Fuel Rail 1 Usage
37 7517405 Screw 2 Usage
38 1253405 Injector, Fuel 2 Usage
38 1500198 O-Ring 4 Usage
39 7670129 Clip, Injector Clocking 2 Usage
40 ------- HARNESS, JUMPER, FUEL INJECTOR [See Electrical Page, Ref. 23] 1 Usage
41 7517259 Screw
There are your part numbers , as to your question which line is leaking?
1 - 2 of 2 Posts
