1 - 16 of 16 Posts
Faaarrrr cheaper than factory Victory pumps. Wonder if they're as good...
100% agree with 53
Reactions: Motorbikerx
What about the filter? :unsure:
I know it's supposed to be replaced at some point in the tank. Not a simple metal screen like my carb bikes.
Yeah Quantum fuel filters in my Vegas, got pack of 3 or 4 for a mere fraction of Foolaris price for one!
My pump working fine on my cross country just not sure when or if I'll need to replace the filter. Bike is 8 years old with only about 30k that I'm trying to add to when I can.
Has anybody here tried reaching in and changing the filters without removing the fuel pump?
Still running the original fuel filter at 148,000 miles.
Your a lucky man and have never got any bad gas. I have a little over 50,000 miles with same filter. I do have a new one on hand, but every time I read your post. I think I'll go a while longer before changing the filter.
I run the cheapest gas I can find.
I had to change the fuel filter on my 04 TC. I don't remember how many miles I had on it, 40 to 45,000 miles. We made a Saturday bar run to New Mexico and I started hearing a whining sound coming from the gas tank. It was the filter stopping up. Changed it out, cleaned the tank and everything was great. One thing I like about the Cross Country is they have a locking fuel cap. The TC's didn't, a Sportster or Dyna gas cap fit it perfectly.
It would be impossible to do that. It is not a complicated job, but does require some time and the proper steps to do it. Just follow the instructions in the shop manual. You have to empty the tank and take the tank off and turn it over on its back to get to the fuel pump at least on all the Victory MC I have seen. Make sure to put it on some soft surface like an old blanket etc so it will not get marred. Take out about 13 or 15 screws I can't recall exactly but you will see then and then pull the fuel pump out then you can get to the filters.Filters have to be placed in the specified place in the tank, then the pump re installed and the screws replaced and then tightened down in proper chis-cross sequence. You should use a new gasket if yours is old etc. Screws have to be torqued and that is just about it. Just make sure it does not leak before putting it back on.
Thanks. I don't have to do any changes at the moment and will be able to get the pump out with a bit of the proper tongue placement. I was just curious if you could get your hand in there and change the filters without removing the pump.
1 - 16 of 16 Posts
