1 - 6 of 6 Posts
Does anyone know what the output pressure is on a 99 V92c fuel
pump. and also the regulated pressure.My pump is dying a slow death.
I want to find an aftermarket pump that will work. The pumps from
Victory are junk and i really don't want to go down that road. This
is the second pump in this bike. if i know the output pressure i can
match something up. Thanks.
Check with VicBuilder for his pumps. I think about 175 and many have used him with no issues.. I can't find the thread that has your PSI in it but its here in V92 or tech forum. I know we discussed it about 3 months ago... for the V92 it is 49psi at the port but I am not sure how your model is set up. Check BBob if you havent downloaded your manual and see if he has it.
Let us know if you need more help or what you got..
Tim
Thanks for the reply. The vic builder has OEM pumps. I really want to
stay away from vic pumps if possible. A pump is a pump as long if it
will fit in the space available and the pressure is correct. I can pick
up a universal pump at Summit Racing 55 psi and looks identical in size. They sell for less than 100 bucks. Victory didn't use a magic pump in there bikes, it's probably a pump that was already being
made that suited their needs. of course they wont tell you that. once i pull the pump i will have a better idea what i will use. if it all works out i will post the make and model i used so others can benefit.
Hopefully on Monday I'll remember this post... I think I have a line on a different maker for the pump and cheaper... I was literally working on it at the time of my crash and obviously got a little hung up
This shop rebuilds them and he is one of Lloydz go to guy he will tell you the truth Rylan is top shel guy
http://thevicshop.com/
1 - 6 of 6 Posts
