1 - 10 of 10 Posts
I had the bike on the lift to check belt tension. As I was torquing down the axle nut, I had to loosen it up a touch and I noticed some play in the links for the shock. Roughly about 1/4" or so, I cant locate any spec for play. Would this be normal?
Its the connection where it pivots on the swingarm
Discussion Starter #2
This is where I noticed the play
there is a guy here BBob that you can download a manual to your computer.
Am guessing it should have maybe a 1/8" side to side play but don't think a 1/4" is what you want
Is #9 a bushing ? If it is , It may be smoked ..... #13 looks like a bearing too , may want to disassemble it for a check . Make sure you have proper torque specs for reassembly , that may be crucial to tightness , and your safety !
The movement is up and and down. I have the manuals on my phone and pc, I'll check the bushing
I found the same play with removing the rear tire. I can lift the the swing arm up and down. I pulled that pin ( shaft ) and see needle bearing in side but i don't think thats the issue.
The pin just slides in and is held in by a set screw that just stops the pin from sliding out, there is nothing to hold that pin tight! Something should keep it tight. ?
sorry mine is different, ( 13 XCT) but still have the play...
Is that side to side?
When I fitted the shock it came with spacer washers which gives a little side clearance,up and down I would say 1/4" at the wheel
you half to remember its designed to have weight on it. Its not designed to be in the air with no weight on it
its normal on the cross bikes and visions
Mine is a 2004 vegas . I don't remember mine having play. I see you are in nj maybe we should get together. Would like to ride with a fellow vic
1 - 10 of 10 Posts
