1 - 20 of 34 Posts
Thor pipe.
Pros:
1. Pipe is light as a feather. Picked up the box and couldn't believe there was a complete exhaust system in there.
2. Pipe is sh!t simple to install. A 12 year old girl could probably get it done without the directions. It was harder to get the Bassani off.
3. The split flanges they use at the header connections are PURE GENIUS. All pipes should have these.
4. The package was complete and nicely executed. The pipe fits tight to the bike and the finish is good. Looks good. Sounds good. Makes the best overall area under the curves of any pipe on the market right now.
5. Pipe was cheap. $532 shipped to my door.
Cons:
1. The connection between the collector and the muffler was a little out of round. Used a U-shaped muffler clamp for a car to 'persuade' it. Tighten, loosen, rotate, repeat. took off the U-clamp, applied some high temperature sealant tightened the band clamp on there... voila!
I read horror stories about installing this pipe, you probably have too. All I can say is this exhaust is as easy to install as RPW Slash (AKA SlashNess) pipes are. Piece of cake.
Just curious, why did you get rid of the Bassani? Ive read great reviews on them.
I liked the way the Bassani sounded and it makes great horsepower... but it dragged on the ground when I got aggressive in the twisy stuff. The Thor will make better overall torque, it's higher and tighter to the bike.
This is what I should have bought in the first place 5 years ago... Back then it was the Ness 2-1.
Rode the bike today and it runs EXPONENTIALLY better. Much less vibration (I wouldn't have believed it). I used to have to keep the RPMs over 2200 because below that the bike was so abrupt it was un-ridable. Not any more. Pulls cleanly from 1800 RPM. It's quieter everywhere except full tilt boogie. Sounds awesome.
I figured it would be torquier but would lose a little horsepower. Wrong. It winds right out to 6200 RPM without any sign of the power rolling over. Tach is taped off at 6200 so I can't see the needle after that.
I'm still going to have Dr. Dyno put a final tune on it at the end of April... but seriously, it's almost perfect.
Thor pipe.
Pros:
Cons:
Where did you get that pipe so cheap?
That looks nice. I'm leaning towards the RPW Deal.
damn nice price, wish I hadnt bought the guitar kit and sissybar lol
Now, that has to get flashed right? I have the stage 1 swept pipes on my 09 KP, I would like to get those pipes
yes... unless you have a fuel controller.
They used to be the Arlen Ness 2-1, and Victory should have a download for that.
nope no fuel controller, just flashed at the dealer.
Niiiiiiiiiice brudda ;)
glad you pulled the trigger!
I seriously think it's not just a great-performing pipe, but the best looking pipe out there...
I still love mine.
Yeah when you get on it, it turns heads man. I know you like the overall output, but I'm so glad I baffled it- toned it down at moderate throttle to exactly where I want it, but the WFO output is still earth shaking, which I also wanted. Best MacGuyver mod I've done to her.
BTW, I also had the sealing issues you had at the same joint. Also ended up reforming the profile and also used an exhaust sealant- addressed a leak perfectly.
Did you use new gaskets?
Discussion Starter #20
Of course! Lloydz gaskets, I bought 2 sets so I'd have some here. I also changed the final drive belt while the pipes were out of the way.
I'm going to visit with Dr. Dyno for a final tune. When this set of tires wears out it'll get a new front brake rotor and a fork oil change with the new shoes. That should do it for this season.
Hey, post a picture of your bike for me, please.
1 - 20 of 34 Posts
