1 - 14 of 14 Posts
I found that the memphis shade bracket part number 2321-0020. Works great on a gunner. Im running it with the pop top and it looks great. Hope this helps somebody.
sorry it was dark when i posted and im at work now i will try to get a decent pic posted after work. also another note is to use the 9" cutout on the sport shields.
I didnt make any modifications to the brackets. Its the same brackets that Memphis shades says to use for the vegas.
i have added an album to my profile called pop top everyone should be able to see it. i havent figured out to attache it to my post.
I ended up bending them and then it has hitting the Speedo. I gave up on the whole thing and bought the lock and ride. Good job!
thanks i didnt bend them they have a slight inward tilt on the fork tubes no more than 10 degrees and it clears the speed by about 1/4 inch. i really like this set up though.
@p_a_guy, just out of interest, how wide are your gunner forks?
Measured from extreme outer on the upper tubes?
Not triple clamps or legs but the actual fork tubes.
13.25" from the outside of the tubes
Ok well Victory has introduced a 'wide glide front' without any fanfare!
My Vegas measures 11.75"
1 - 14 of 14 Posts
