1 - 3 of 3 Posts
What all is different on these? Do the freedoms motors have exhaust studs or bolts. Trying to mount a TC exhaust on a 99 hammer motor and wandering if this is part of the trouble. Mine has studs.
My '02 TC (Freedom engine) has studs sticking out of the head. The exhaust pipe clamp has holes that go over the studs and nuts pull the pipe in tight.
Are you sure the old gaskets were removed? Doubling up gaskets would make the pipe stand further out and the studs would appear too short.
What I don't know is if the two engines have the same size exhaust ports. The pipe diameters and the hole spacing of the studs could be different.
Hope you get it to work.
Thanks, I think I was doing something wrong. I have some new information and hope this helps me to figure the exhaust out.
1 - 3 of 3 Posts
