1 - 13 of 13 Posts
I'm looking for different handlebars but the knurling center to center on my Vegas is 5" and everything I'm looking at is less than that. I've looked for sites that list center to center knurling info but can't find it. Got any ideas? Does one of the other bike makers use the same center to center?
Just look at the inches it should say 4.5" if I remember right. Just measure were your bars clamp down, the spread. I just got some for a Harley from J&P Cycle and I believe they are 4.5". I held them up to the stock bars yesterday and they look like they ought to work fine. Now I just got to take the time to put them on. Oh, and they were not $150 or $200. They ran me I believe around $53.
I looked up handlebars but they won't work unless I want to see the knurling on the inside of the risers. I just measured them and center to center is exactly 5". I need bars with center to center of 5".
I found a set 32" wide, 9" center, 10" rise and 6 3/4 pullback. Perfect. They aren't knurled and I've used them before. One piece of copper shim top and bottom and they aren't going anywhere.
I put un-knurled buckhorn style bars on my Vegas and they tightened in the clamps and stayed tight just fine.
They usually do. I put .001 copper shim in because it helps grab.
Good idea with the copper.
Installed the mini apes. 10" high handlebars.
When the weather warms up I'll remove the windshield
and get some better shots.
All shots:
D300
24mm Ai f/2.8 at f/4
Added a shorty windshield. I didn't like the huge one, I thought it ruined the lines of the bike.
windshield
could you give me the measurement of your glass? also where can i get one i got the flyscreen but to small
Discussion Starter #13
12" wide 14" tall.
It's a Victory windshield so you can get it at the dealer.
1 - 13 of 13 Posts
