1 - 3 of 3 Posts
2011 Victory XC
Went to Rolling Thunder Sunday and after returning home got caught in a thunderstorm. Noticed today on my way to work I cannot completely downshift while at a complete stop like I used to. I have to let the clutch out just a little and then it will downshift. If I am riding normally and go to downshift I have no issues. Its only when in rare circumstances that i have to stop very quickly and cannot downshift in time. I also notice I hear a tap tap tap sound while in first and I have the clutch pulled in and I am coasting in first gear. If I let the clutch out the sound goes away.
Any suggestions would be appreciated.
Just a thought; clean, lube, and adjust the shifter linkage. If the problem persists, it may be time for new bushings in the linkage arm.
I have experienced similar behavior when I installed the EZ-pull clutch arm and did not have it properly adjusted. When fully pulled, the clutch lever was not sufficiently pulling on the clutch cable. To remedy this, I tightened the cable at the adjuster effectively shortening the cable and taking some of the freeplay out of the clutch lever.
G'day,
Vinish
1 - 3 of 3 Posts
