1 - 5 of 5 Posts
wondering what the diameter is that I need to look for for a slip on exhaust that is "universal fit"
I haven't seen any YouTube videos of a rinehart slip on for one of these bikes, but I'm not sure what size the hookup needs to be. Mounting brackets are easy enough to fabricate if need be.
Just look up aftermarket pipes, many will tell you the inlet/outlet sizes along with length. U'll like some new sound
I am assuming you do not want to remove the stock mufflers. The vendors above may be able to give you an O.D. dimension of the header pipe. A Victory dealer may also be a help.
If the slip on mufflers on eBay are close, but a hair big, the side of an aluminum can may be able to make up the difference.
Good luck with your project.
1 - 5 of 5 Posts
