1 - 4 of 4 Posts
I have to have to post in order to acces the forum, so here is my first question.
I would like to install new headlight bulbs and the problem I am having is the proper way to remove the front bezel. Is the a lever tool I should use or just pull evenly on it. I'm in that phase that I don't want to mess things up removing the bezel. The manual doesn't specify removal techniques .Thanks
next time say what year and model you have.
might be a Phillips screw on bottom of bezel.
If you need a H-4 bulb you can get at auto parts store if you want to save 10 bucks
Bezel removal
Sorry I have a 2014 cross country. It takes a 881 bulb,but I want to remove the bezel without damaging anything. It was recommended that I use a windshield lever to pry it off.
Who recommended that?
There's one screw holding it in place, at the bottom of the bezel. Once the screw is out, use your fingers to pull it out.
1 - 4 of 4 Posts
