1 - 2 of 2 Posts
I apologize if this has been covered here before but I could not find it if it has.
I had the shop switch out my headlight for the Judge which I think comes on HB's now. Anyway there is no connection kit so we had to wire it in. The indicator bulb connection plugged right in but he had to make connectors for the dim, bright and ground connections. Everything works fine but the bright light indicator stays on all the time now. Any suggestions?? The guy at the shop was a good guy but it was his first one. I started to do it myself but I watched and would have done exactly has he did. Not a big deal but I'm anal and it bothers me.
Thanks in advance for any ideas. I know there are several of you that have switched out the headlight and may have encountered the same issue.
You should only have three wires going to light. Low beam power ground and high beam power. Your indicator light should be wired to high beam wire only. start looking and having a volt meter will really help you
1 - 2 of 2 Posts
