1 - 5 of 5 Posts
So I have tried to find the thread that I saw this in but even using the search function I am unable to find the information.
If I remember correctly the thread stated that the plug under the seat (looks like a battery tender plug) is for the heated seat. My question is has anyone used this to connect heated gear? Do you know if you could run 2 sets of gear (less than 16 amps) from that?
Thanks for the help!!
On my 2013 XCT the heated seat wires are coming from the rear fender area and it is a plug with 4 or so wires.
I ran wires for my heated gear under the tank and down to the battery. There is a terminal block on the left side of the battery box area. I ran the hot wires there and the ground wires to to ground on the battery. Make sure to include a fuse in the hot line.
off
If I remember correctly the threadi stated that the plug under the seat (looks like a battery tender plug) is for the heated seat. My question is has anyone used this to connect heated gear? Do you know if you could run 2 sets of gear (less than 16 amps) from that?
Those wires control the trunk tail and brake lights and the trunk speakers. Im not a mechanic but i think you'd be better off running a separate set of wires as already suggested above... I doubt the light wires would handle 16 amps...
Sent from my iPhone using Motorcycle.com App
Isn't there information in your owners book about what wire for seat.
I'm sure it would have diffrent end for the seat
The plug that I am looking at is not for the trunk. I am familiar with that plug as I run with and without the trunk at various times. I will probably just go the safe route and run it to the battery.
Thanks
1 - 5 of 5 Posts
