1 - 10 of 10 Posts
New Member Looking for Help with 2005 Victory Vegas 8-Ball
I am a new member looking to be pointed in correct direction for different issues I am having.
Discussion Starter #2
So what are some common problems others have run into with 2005 victory vegas 8 ball. New here and just purchased a 8 ball looking to get all info and as much help as possible as I am finding most Mechanics in area are unclear of victory and more familiar with Harley.
Luckily you won't need any mechanics since it's not a Harley. :ltr: Congrats and welcome to the forum. cheers
Welcome mine's an 04 and like the others said clutch cable and throttle body then ride the **** out of it.
Discussion Starter #7 (Edited)
Appreciate the help!!
Thanks for tips above ^^^^
Purchased at 15k ,now at 17k ....pipes,carlini bars
I have read that a few people have had problems with getting into neutral, i also have that issue seems like Clutch went out after ride this weekend would not shift down into gear when coming to stop,and when i was in gear cruising and got on throttle the torque was delayed, sound was there but no pull for a few seconds. I cleaned the clutch lever at the cable attachment after ride , but I'm pretty sure clutch is burned out . I was given a Barnett clutch assembly new gonna try that next with the throttle body tip!
Sometimes fresh oil 'n' filter helps here though not always... Good luck.
If the old owner gave you the Barnett clutch he new the old one shot.
1 - 10 of 10 Posts
