1 - 9 of 9 Posts
So my beautiful bike with only 20k miles is sitting with these parts needed:
Rectangle Font Parallel Electronic device Electric blue
Rectangle Font Parallel Electric blue Magenta
No help from Polaris and no dealers have these.
Does anyone know of an aftermarket solution?
If not, anybody have a good, used sprocket?
I can still get the nut from a few dealers.
THANKS POLARIS!!!
Does anyone know of an aftermarket solution for the 30T drive sprocket for 05 Vegas?
Somehow you need to find out the out put shaft measurement and if the splines are different.
I don't think Rylans taking calls unless you pay to "join". Maybe Noe might know.
After '03 when they came out with the Freedom motor I thought the front the front sprocket stayed the same.
Some of the 8 Ball models had the 5 speed even though the 6 speed was pretty much standard.
RT Thor would know for sure, he's over on the VOG.
Discussion Starter · #4 ·
Thanks and I'll join VOG and post there...I appreciate the help!
View attachment 258706 View attachment 258707
THANKS POLARIS!!!
THANKS POLARIS!!!
CONQUESTCUSTOMS.COM OVERDRIVE PULLEY 32 T
THANKS POLARIS!!!
Why would you need a new sprocket after only 20K?
Discussion Starter · #8 ·
Someone answered this question for me on another forum and he was exactly right. The nut that keeps the 30T sprocket in place on the spline vibrated loose. The nut backed all the way out to the inside of the housing and allowed the sprocket to travel out on the edge of the spline. Over time the inside teeth wore off and allowed the sprocket to spin free finally...leaving me stranded. Outside 30 teeth are all perfect. I had no idea as I just checked belt condition and tension with no issues ever seen. So if you have a Vegas or similar make sure you check that nut! Vic Shop sold me a used sprocket and oversized nut. Installed with another nut and lots of lock tight this time ; )
1 - 9 of 9 Posts
