1 - 9 of 9 Posts
I have a 2015 XCT and recently noticed that I didn't have high beans nor high bean dash indicator. What could be the culprit?
The high beam bulb is burnt out ?
Bulb is fine. Replaced the bulb and results are the same. OBTW I have HID low beam and OEM high if that helps.
High Beam
Check for power to and from the switch for high beam. Also check the ground for the High Beam bulb.
How's about the fuse box? Any blown ones in there?
Not Fuse
Because the low beam is working, the fuse & relay are good. The left handlebar switch has power in on pin 1 from the relay and out to the head light on pins 2 & 3. Low beam on pin 2, and High beam on pin 3.
Wiring bug
The fact that the High Beam indicator on the dash doesn't come on, and the low beam works, tells me the switch or wiring is the problem. Electrical wiring problems are sometimes hard to locate. Take your time and think about each step and with some diligence you'll figure it out. Once you find it, should be a easy fix.
Reactions: BenD
I know this is an old thread, but did this ever get solved? I have a '15 XC with the same issue. Bulb, relay, switch all test good.
1 - 9 of 9 Posts
