1 - 2 of 2 Posts
I am trying to find information on cleaning the fuel injectors on my 99 Vic. The service manual has no reference to it. I have cleaned the throttle body throats and plates, lubed the cables and replaced all the filters in the fuel system. I would like to know if you can clean the injectors by hooking up to the pressure cap on the rail, after disabling the fuel pump. I have the 3M fuel injector cleaning kit with the adapters and fuel pressure gauge etc. Can this procedure be used on the bike?
Just seen this post Ray. I havent seen anything in any of the forums or heard anyone speake of doing this for that matter. I have heard both pros/cons of Seafoam or the like for cleaning your fuel injectors. Most of the concerns seemed to be around the corrosion prohibitor in the tank. I have ran 1/4 can seafoam through two tanks and as far as I can tell, bike is runing fine. Red corrosion prohibitor is still very visible in tank. TB cleaning was the big ticket in improved performance to me.
Tim
1 - 2 of 2 Posts
