Here we go again.
217 views 3 replies 3 participants last post by  Blue92
#1 ·
Hey guys. I was on a ride tonight and suddenly noticed a misfire.
Got home and again the boot to the throttle is tore.
so my question is what can cause them to tear apart so frequently. Also I noticed that the two throttle ports the front is more dirty. And in the intake there is a bunch of build up.
I have not seen any lose of oil. So I am not thinking blow by. Maybe just carbon from the misfire. Thoughts and suggestions are appreciated.
#2 ·
Don't know what's going on with the throttle body adapters, seem to have been a rash of them lately.
Even when ordering new ones some are having them split.
I've owned 4 pre '08 models and only had to replace one and that was on a Hammer that had sat covered on a carport for 5 years. Replaced another on an acquaintance's bike a few years ago and it's doing fine.
As to why the carbon build up I've no idea.
What I have done to ALL my Vics is reroute the crank case vent hose to the ground and use a K&N filter to prevent dirt build up. Not that it would get in the engine just keeps the residue from the oil mist off the bike.
I started doing this with my Harleys back when they started venting the crank case into their airbox.
I just don't need an oil mist going into my intake.
#4 ·
Well I might be a fault on the boot who knows.
I am going to try a temporary modification. I have used some hose that is just barely bigger than the boot. Slid it over tge boot and the intake tubes.
clamp on both top and bottom.
it seems a little more ridged.
the air box does sit a little higher as well.
we will see how this works. Maybe a new method to run with. I am most definitely going to be putting a crank breather on the winter as well
