1 - 4 of 4 Posts
I just purchased High and Low beam kit from VictoryHID.com. There do not come with any instructions, which is fine it seems easy enough. But the bulbs look the same, are they the same bulbs for High and Low?
Yes. Just be sure you wire them up to the right connectors. You don't want your high-beam coming on when you start the bike, and the low beam when you turn on the brights.
I just did mine today. The wire to the top bulb is labeled for your convenience. :)
Yes, what Lo-Dawg said. Upgrade one beam at a time, and test both beams prior to closing the headlight bucket, just in case something was left unplugged.
Btw, do it yourself instructions can be found here: http://victoryhid.com/support.php.
Lo-Dawg, let's see some pics! :D
1 - 4 of 4 Posts
