1 - 8 of 8 Posts
My 2015 CC VS a Co-Workers 2012 CC. Difference is his has the timing wheel set to +8 mine is +6, his has cams and a 2-1 home built OEM exhaust otherwise it's stock. Same dyno.
Seems about right. That dip in his torque right across the mid range might be his exhaust. And if his bike went to 6k RPM it would add a few HP. Vin, maybe you should build him an exhaust.
Vin, the only thing you have is the timing wheel?
I posted the difference between timing wheels the rest is in my sig line.
Vin your lines match up nicely with what my buddy and I got running +4 on our bikes with similar setups to yours.
Seems they all run about the same.
1 - 8 of 8 Posts
