1 - 10 of 10 Posts
Can't find a post on this. Friend has Magnum and when he honks horn radio quiets. Wondering why
If he has an aftermarket amp and speakers setup and/or different horn, I can speak from experience it has happened to me. I think it calls for a diode on the horn to keep it from happening. It's only happened when I've hit the horn several times in succession, after a a few moments it comes back on if I remember correctly.
you know what diode and where to get one
Reactions: broggyr
Tell him to check those battery terminals tight as well.
Reactions: BBob
I think the only time you would have the horn problem was with the Wolo/Stebel. I wouldn't think an OEM horn would cause problems.
What horn is he using ?? Stock or aftermarket ?
Sent from my Lenovo P780_ROW using Tapatalk
stock radio no amp and stock horn
After all that's been posted, I'd have to say check battery terminals.
Reactions: depot picker
1 - 10 of 10 Posts
