1 - 3 of 3 Posts
Never had this in 18,000 miles. I' ve done this 100 times. Washed the bike yesterday, couldnt ride because of the weather, thought I would wash and wax every inch of the bike. Spent about 2 hrs doing this. I used a garden hose trying not to get water on controls and various other electrical locations. Wiped off the bike, then waxed & polished it. Getting ready to put back in garage, I started it and the horn started blowing. Turned key off, turn key on, horn blows again. I did this maybe 4 or 5 times, horn blew every time. Finally I started it and drove it in the garage with the horn blowing. Let it run maybe 3 mins., then it stopped. Im just thinking, what if it does this when Im riding it. Think maybe something got wet to cause this? What do you think?thumb up
It sounds like a drop of water is touching the two wires for the horn in the swtch housing I'll bet.
Open switch housing and spray in side with some we-40 or what ever you use.
Even check down by horn. Pull each wire and spray with wd-40 and put back and see what you come up with
1 - 3 of 3 Posts
