1 - 3 of 3 Posts
I have quite a bit of tarnish on what should be the glossy aluminum ends of the cylinder fins. Has anyone found an easy fix for this?
From searching the net, I think I can fix the black areas using bathroom cleaner followed by Armorall or similar stuff.
But on the glossy ends of the fins the only thing I can think of to try is a a buffing wheel. Over time it seems to work, but man! it takes a lot of time. I'm also unsure whether the fins are raw aluminum or if they are clear coated and the corrosion I have is under a clear coat.
Thanks! They all like this?
Sound much easier. Thanks again, Johnny.
BTW, as the bikes come from the factory are the fins clear-coated (to avoid having to polish), or do they all require occasional polishing?
1 - 3 of 3 Posts
