1 - 8 of 8 Posts
My 12 Vegas has a loud humming sound coming from the area of the rear wheel upon slowing down, maybe 5mph then it stops. It only occurs when I'm slowing to a stop. It's not brake noise because it occurs when the brake isn't engaged. I'm thinking if it was a bearing it would do it all the time. I've owned several dozen cruisers but never have had this issue. I'm thinking it may be the floating rear disc? Any help would be appreciated...
Bet it's your belt - check for tension and alignment. If you want a quick check to see if it is the belt - spray it with some liquid teflon of rub a bar of soap on it - take it for a ride if the sounds gone....you got the culprit. Very common problem with belt driven bikes.
Tension feels ok, but the alignment may not be. Check out the pic I attached. Belt is to one side of the hub, not in center. Is that normal?
From my experience, most belt drives ride to the outside of the pulley, probably due to centrifugal force or something. The main thing is to make sure the wheel is aligned per the marks. My 2011 Vegas makes the exact same noise. I have 3000 miles and it has eased a lot. I did adjust my belt in the beginning, and sprayed it with the Teflon spray. Those things helped minimally. Break in time helped the most.
Thanks maybe I'll leave it alone..I was concerned it may be something serious but it appears not.
According to shop manual, belt is supposed to ride on the inside of the rear pulley when wheel is in forward rotation. Since it's new either swing by the dealer or mention it when it goes in for the first check.
Heading out to service now.
Thanks..
Ok the verdict is in..normal belt noise. The Vic tech rode it and said yes the belt is tight but they are told to do it that way during break-in. He said the sound will diminish as miles are put on.
I'm good...at least it's normal. I'll get used to it like I did with all the strange noises on my GT500.
Thanks again to all...
1 - 8 of 8 Posts
