1 - 3 of 3 Posts
Didn't see anyone mention this before and nothing came up on searches.
I had a feeling I'd have some interference after looking at some close up pics on bikes without the primary cover and sure enough, my Kuryakyn primary cover will not allow the Hyd clutch actuator to align with the clutch arm. Anyone else run into this and if so, what route did you take to be able to use both pieces together?
I still plan on using both the primary cover and the Hyd clutch, so my only option is to notch out the primary.
Actuator touching primary cover. Note the actuator rod would bend if forced with this setup.
Primary cover removed and actuator installed
Section of the Primary Cover that needs to disappear
Cable routing
Only seen two others and they ground the plate to make it fit
That's what I figured. I'll double check my marks tonight - measure twice, cut once.
1 - 3 of 3 Posts
