1 - 4 of 4 Posts
Reaching out to anyone who has had hyper flash problems on their turn signals.
My turn signals were not working so I replaced the auto cancel module but began hyper flashing on my front-right turn signal and the rear-left does not flash at all.
The left side is fine.
What I am not sure about is the module I purchased, the module is approximately $300.00 but I fount a Victory parts website with what appeared as the original component for significantly less.
It worked fine for a few days but then the problem started.
I don't know if it is the module or something else.
U lost me here, please clarify...
Front right blinks fast, does the rear right blink fast as well, or not at all?
Rear left doesn’t blink at all, does the front left blink fast, blink ‘normal,’ or not blink at all?
Something to consider: if ONE flashed bulb fails to work, its mate at the other end of the bike will hyperblink, the same hyperblink may occur if u replace an incandescent flashed bulb with an LED bulb, this is because the LED unit draws such a small amount of juice, the bike’s flasher circuit thinks it has a bulb out, installing a load equalizer will help with that.
1 - 4 of 4 Posts
