1 - 4 of 4 Posts
So i'm shopping internal throttles and was wondering if anyone knew off hand what the inside diameter is of the highball stock apes ??
if you have your old bars it would be the same I bet.
You would want a throttle the same as harley's. 2000 to 2007
I'm guessing you have one inch bars.
I think I'm going to keep the stock apes. I just want to make sure the inside diameter is 1 inch which i s the same as the internal throttle I'm getting.
Just went to the garage to check for you.
Outer Diam.=1.25"
Inter Diam. =1.00"
Pipe Wall Thickness = 0.125"
Keep in mind that at elbows, there will be a totally different story.
1 - 4 of 4 Posts
