21 - 40 of 40 Posts
Why over think this,
OP did you drain the oil?
OP then put the bike on its side
OP then spray / pour with a flexible hose some petrol at the high side of the engine case
Then it will wash to the lower side of the case, take a small hook and fish it out
Then put fresh oil it your engine, run it for 5 minuts / dump the oil and put new oil & filter in it
Then ride that beast
Andre using TaPaTaLk
Reactions: IndyVictory
dougie d
have you made any progress
Pulling primary won’t help. Drain oil, remove timing chain cover, remove timing gear, elevation or rear slightly and leaning bike hard right. With a flexible claw retriever insert into large cavity below crankshaft. Locate with a flashlight and retrieve it.
Discussion Starter #27
Thanks this sounds way easier then pull off the primary
Had a local guy do same thing.
Any update?
Reactions: visionjohnny
I try your suggestion and still cant see the piece in there. Gonna give the dealership a call and see what they can do to help me out.
screw the dealer. Keep trying do you have a led flashlight. if you have timing cover off maybe you need to take the primary cover off. Do you have a coathanger wire to do some fishing around to fid it.
You did drain the oil I hope
Discussion Starter #33
Im gonna keep trying. Dealer wants 2500 buck .oil been drain.
Discussion Starter #34
Nephew came by today. He had the piece out within half hour. THANKS. So much for the advice.
THANKS for your advice. Nephew got piece out today in about half hour
Tell us how he got it out.
Awesome. Glad you got it.
Reactions: dougie d
WOW! great to here you got it out. The price the dealer gave you is outrageous, 2500 dollars..
Now I can sleep it at knowing you fixed after a week.
Glad you didn't go to the dealer
21 - 40 of 40 Posts
