1 - 3 of 3 Posts
on a 2001 vic how do I adjust the idle air bleed, and where is it located .
regards,
greg
is it the 2 elbow joints on the right side of the throttle body ?
if so how can that be simple adjusted .
I guess I could open up the joint a bit and install a brass jet , like the s and s e and g carbs .
regards again ,
greg
You do understand this is a fuel injected engine? There is an idle screw-that you can raise the rpm's with no problem-lowering it messes up the tps settings and the bike won't run well. What exactly are you trying to achieve/fix?
The 2 elbows on the right side of the tb are vacuum ports, they should have rubber caps on them. If they're cracked or missing, they need to be replaced
1 - 3 of 3 Posts
