1 - 8 of 8 Posts
hi idle problems with my 2007 hammer anyone
Check your cable...make sure it has not moved from where it should be on the throttle body. I have seen the lock nut back off a bit and the cable move out of position.
make sure your cable is not bound up...also may need an adjustment on the return cable if you have two...return cable is on the bottom.
1 - 8 of 8 Posts
