1 - 13 of 13 Posts
I have been searching on here to see if anyone has relocated the ignition to the fairing of their Cross Country. I have not been able to find anything so if anyone has or knows of someone that has I would appreciate a link or photos of it. And maye some info on how they did it.
I did not move mine too the fairing but I do have web site and part numbers for the plugs so that you could make the harness and not have to cut factory wiring. I can get them tonight if you want
I would like to know if anyone has moved it to the right side. If so where and how.
What's wrong with the left ¿
Andre using TaPaTaLk
I like to be able to hold the clutch in and turn of the ignition. Not hit the kill switch then the ignition.
That is a good reason, and never heard of that, ..... Anyway I read 1 or 2 years ago that there was a guy that cleared all the stuff behind his right hand cheeswedge... So yes it could be done.....
I relocated switch
I got the bracket from Witchdoctors Bueller is taking about. Also got a small harness they sell. They sell it to move the switch behind the rear cylinder. I moved it up onto the bars, but I went to the left side of the handlebars on my XR not a CC. I lost my ignition key once in northern Az. every since then I wanted to move it, so I got the parts from Witchdoctors. The key could still fall out, but it is pointing down now, so it is less likely than the BS location Polaris put it in.
dirty
Dirty bike. Not a garage queen. Gets used. Ha,ha. No plans on buying a new bike that is black again.
1 - 13 of 13 Posts
