1 - 10 of 10 Posts
Sometimes when I start and run the Ipod doesn't connect. I thought this might be the connecter at the back because they are so flimsy. Turning the bike off and on has instantly cured the problem when it happens sometimes.
Yesterday I started and ran but noticed the radio screen is BLANK. This was a first and the bike was hot. I wiggled the key and didn't get anything to blink but turning it off and back on cured the problem.
Those two symptoms remind me of a low battery condition where I suspected a switch problem because wiggling the switch would sometimes allow the instrument panel to light up/ fuel pump. Sometimes nothing during the dead cell battery failure.
Can we buy a new ignition and put our lock cyl into the new switch?
Just shooting in the dark here, but have you tried squirting some contact cleaner into the lock?
I have not made a real inspection yet but my experience from automotive industry tells me I may have gotten a loose/bad one. GM had a lot of bad ignitions and some lawsuits with cars shutting down by themselves.
A contributing factor to that was people hanging a bunch of additional keys and crap on their ignition key chains. Too much weight and a key handle with a hole at one side, not on the center. That provided enough leverage to rotate the key.
My ignition keys have nothing attached and I carry another in my pants pocket. You all might do that too.
Disappearing key
I do have a lite plastic key fob on my key. Made me think of the weight thing causing problems. I was up in northern Arizona a couple of years ago and stopped to gas up, my ignition key was missing. It had fallen out of the ignition with the bike running. I like to learn the hard way. I removed the ignition switch in Page,Az. Had to barrow tools to do that. Took the complete ignitions switch and had two brand new high quality premium keys made for around $80.00, which I was actually very grateful for and very happy that's all they cost. Figured it was cheaper than renting a truck and hauling my bike home. Since then I always carry an extra key, do not hang extra keys on it, and I have an extra at home also. Since then I have also move the ignition from the side mount system up to the handlebars, which I like much better. Oh and yes the new keys have warn down and yes it will come out of the ignition switch in the run position. I personally think the Victory (China made) ignition switch is a cheaply made piece. When it fails I may wire in one from a Honda or a Suzuki, or a NAPA ignition switch.
:nerd
Very true however there were tech pubs about faulty Switch housing for manufacturing reasons too. Intermittent failure to start see key etc. Really shitty cars and they ( GM ) even admitted to it. All the focus was in trucks SUVS.
Took ignition off tonight and cleaned all around it. I didn't take apart the back two screws because I couldn't cause a single flinch so NPF. Will squirt her later.
1 - 10 of 10 Posts
