1 - 3 of 3 Posts
I am looking at getting some new front indicators for my Highball and I need to figure out which mounts to go for. I going to get these indicators:
http://www.ebay.co.uk/itm/151197595463?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I have to decide which mounts to get. Vic Only have these: http://www.victoryonly.com/ACCESSORIES/2003_2011_victory_VEGAS_light_mount.html
Kewl Metal have these: http://www.kewlmetalstore.com/product_info.php?cPath=689_691&products_id=750
I can see the Kewl metal ones work and I know you can see the wiring a bit.
What I can't figure out is how the VicOnly ones run the wiring. I can see they fit nice and flush on the forks but how does the wiring work?
What do you all think I should go for?
Looks like on the Vic mounts that the wiring take a hard 45 degree turn. If you look closely, you can see that there seems to be a drilled out area for the wiring to go out the back. I think the Vic mounts look better but it is certainly up to each person's taste. Good luck. I do like the lights you have picked out.
Thanks for the reply. Just looking at the pictures again. I am not sure if the indicator thread is right size to go through the whole on the Viconly ones either?if that hole is 9 mm and the indicators have a 10 mm thread that is them out of the question right?
1 - 3 of 3 Posts
