1 - 4 of 4 Posts
Hey fellow wrenches.
I'm going to be swapping out rear brake lines (both the reservoir/supply and caliper/pressure lines) on my 2011 kingpin due to the conversion I have done from floorboards to vegas Ness-style pegs, in search for more cornering clearance.
I've got the vegas lines, and I have a good idea of where the lines run. Just curious to know how many hours that job has taken others that have had to entirely remove and reinstall both lines. I want to know how much time to set aside.
Thanks thumb up
Discussion Starter #2
Anyone? Kevinx?
Depends on how quick you can get the air bled out. Swapping the lines should only take 15 minutes or so, but getting them bled properly could take a while.
good to hear. starting the process with a mityvac to get some rbf600 in there (hardest part in my experience is getting it started if you don't have a way to suck the fluid down past the master to get the flow going). then i've got a trick little one-way check valve that allows me to bleed without a helper... cool stuff
thanks man
1 - 4 of 4 Posts
