1 - 12 of 12 Posts
Installed Thirdgears Customs intake and Power Commander V (with a base map from them) hope to dyno next week and let y'all know the gains. My butt dyno feels like a lot stronger mid range. My 1st dyno was 93hp 113tq hopefully I'll break into the 100s now.
That's awesome. Love the big T-bars too!
curious to see the numbers, no cams or yes cams?
No cams yet. I'll post once I get it on the dyno. The local Harley dealer is the only local dyno and dyno guy was sick today so now have to wait until the 13th of April.
Power potential is there. Running a base map that was really lean produced 100hp 115ft lbs.
I added fuel to the map when I got home and this baby will flat get it. If I had better exhaust I would be seeing a huge jump
That looks great, curious to know what cams will gain. I have essentially the same setup as you except with the auto tune function. Runs so good now that I cant imagine the cams!
cams would jump you up about ten more horse. Coast might not warrant it
If you think that auto tune works as a closed loop tuning system. You Are mistaken. Auto Tune needs rider to accept trims to adjust. After about six cycles the system is supposed to me removed
Its actually the PCV that taps into your o2 sensors and creates a wideband. Monitors AFR, MAP and exhaust. It actually adjusts to optimal AFR, enrichament, enleanment and ignition at all times. Its technically a piggyback
Tunes are great, but at 2-300 a pop, that would get expensive after 4-5 different parts.
Ive had about 10 different sport bikes, about half had this or the Bazzazz system works great.
And 10hp, that is a ton on a bike. I would take 4hp for the price of the cams. On my ducati superbike with full termigonis exhaust, Ducati performance ECU and airbox i netted about 7hp. That was about $2500 worth of parts vs $450 cams
Chezgetssome
you should move that little blow by filter down to point at the ground. That way it wouldn't puke all over the motor
mods
Lloydz LSC CAMS, ATS, 1/4 turn
Norseman performance exhaust
Third gear customs intake
PCV tuned by Josh Coastal Indian
Under drive pulley, MSD coils and wires
119hp and 118ftlbs made 102ftlbs at 2000rpms
1 - 12 of 12 Posts
