On my way to a dyno tune nip and tuck yesterday I noticed my horn would only work randomly. It didn't matter if I restarted the bike or not. It simply may or may not work within any number of miles. I'll try shooting some contact cleaner in their and see if that improves anything. Does the horn run through the flasher relay at all? I didn't see that it does when I looked on line last night but I may not have been looking at the proper wiring diagram. My 4 way flashers and turn signals work 100% reliably each and every time.
When leaving Charlotte Indian yesterday after the dyno run, my ABS light stayed on longer than it ever has. Josh said it was because the bike was running on the dyno without the front wheel turning. Sure enough, by the time I was leaving their parking lot a second time it went out. Then when I stopped for gas an hour later, it stayed on for the next 180 miles until I stopped for dinner and fuel again. It went out about 10 miles down the road after that stop. I'll try to wipe the front and rear sensor and check the associated wiring this weekend. Maybe it got some dirt or an insect blown in their in the dyno room.
