1 - 4 of 4 Posts
I like the sound of the Guard Dawg keyless RFID. It appears that you can remove the ignition completely. I had thought of moving the ignition. Seems like brackets and extended wiring is fairly easy to get so I thought maybe do both. Does this sound stupid? I think I would like to fill the original ignition position with a starter button.
Has anyone used a GripAce? This sounds like a good way of cleaning up the wiring on the left. It appears to have only has 1 wire that needs to run inside the bars. I like the look of an Exile bike on the GripAce website that has it mounted in the handlebar. I think this may be too far to reach easily with the lever mount. The suggestion is to have it mounted in the grip.
I like the idea of an internal throttle but I'm not sure if the angles on the bars would be too extreme.
I would really like to have everything internal (reservoirs, brake lines, clutch, throttle, all wiring) and I know anything is possible with heaps of cash but unfortunately at the moment that's not me.
wires ok inside bars cable maybe not they could kink up and that would be bad.
Where key was why not power out let to charge phone
Yeah my thoughts were the cable may kink up. I think just getting wiring internal would clean it up a lot.
Power out is a great idea. I know the GripAce has the start function as well.
I could see a smaller, cleaner switch housing set, but the thought of controls in the grips doesn't appeal to me. I'm all for cleaning up the high-ball front end though.
How about any aftermarket slick control housings for Vics? There's only a gazillion out there for Harley.
1 - 4 of 4 Posts
