1 - 15 of 15 Posts
I looked up TPS p/n and found the only way you can get one is buy the whole throttle body for $369
Guess maybe you can find one at auto parts store.
Why is victory doing this. I found out on vision if stator goes out you have to upgrade to 2013 or newer and that's a kit you have to buy for
$265 and no you can use take off parts cause the crankshaft is different on both models. Yes you need a new regulator too
So will it be cheaper to buy a new bike
They are crazy , we , or at least I , am SMART for owning one !
So what about a Ricks?
TPS is the same as other motorcycles... same old 3-pin ****.
Victory...
JP Cycles, $34...
I picked up a TPS last year from autozone. All of $12.95. Same exact part (mfg & part number match), except it's listed as a TPS for a Ford explorer/expedition.
Cool info guys ....
Yeah Victory stands for "Vive hundred dollar"
HD stands for "hundred dollar"
Maybe it's just me but $265 for an OEM Stator doesn't seem that high. It was $150ish for a Rick's for my GSXR when that went and yes the regulator had to go too (another $120) and that's on a model that is notorious for having that combo fail.
The not being able to buy a TPS is weird but seems like it's easy enough to find when you have the right resources (read: this forum).
Also not like these are wear parts that are common to be replacing. They are common issues but again it's a frequency thing.
Its almost like Polaris/Victory doesn't want to have a warehouse full of parts or the many power to pull them. $60 dollars for one black spark plug wire or $114 for a clutch cable aftermarket clutch cable is $80 bucks.
I don't understand
Aftermarket is always cheaper than OEM. That's not really much different with cars.
Its the only real downside to Victory ownership, lousy spares backup, inability to supply small parts ( you have to buy a complete unit eg. Bullet headlight, rear brake caliper) and ridiculous prices!
Interesting finding Polaris does the same with Indian Parts as well .. Had a Slight Cracked Turn Signal Lens .. Had to buy a Complete Turn Signal Unit even though the lens was very easily removed with a screw driver and the Bulb itself was changeable as well .. No Bulbs or Lenses sold separately ..
Well gator at least you can change the bulb if need be.
I did a post mortem on my blown license plate light on my 2010 Vegas its a sealed up unit carrying
A normal bulb inside!
I bought a Narva LED trailer light and filed it down to fit.
Wasnt game to price one out of Victory.
We certainly getting shafted!!!
On the new bikes Vic sells it with the throttle body because it is adjusted to a closed spec. Get it adjusted wrong, and it can run like crap. They are different then the pre 07.
The new style can be purchased from Walker Products for $39.99
PN 200-500MC (714)554-5151
The plug wires are $60 each for black, but Vic sells red and blue sets for $40
1 - 15 of 15 Posts
