1 - 4 of 4 Posts
I just received the Linbar and Kuryakyn ISO flame grips for my Jackpot and there is no throttle sleeve in it. Do I cut the factory grip off the throttle sleeve and then install the new grip? :confused:
Only the left grip is glued, you will reuse the throttle sleeve. At least that is how it works for me on my other bikes. Should be some directions with your grips as well. Be sure to use a good glue.
I think you got 2 left hand grips call them and ask a tech.
No groves instructions say to cut original grip off and sand the throttle sleeve???? I read the instruction before ordering online that they came with the throttle sleeve. I went back and reread the instructions and it only applies to the ISO grips not the ISO flame grips, sent me grips that say universal 1 inch handle bars.
One has a smaller inside diameter for the left grip.
1 - 4 of 4 Posts
