1 - 7 of 7 Posts
I have had a 2005 Hammer since new, have rarely ridden it in recent years, but am joining the forum as I get the hammer back on the road. The fuel system has suffered from disuse over the last few years!
Welcome to the Forum !
Welcome and give Seafoam a try.
Thanks! I did try seafoam and techron to no avail. I also had the fuel system cleaned at a local shop (our local Victory dealer is still in business as a motorcycle shop, but they no longer sell or service Victory bikes.)
When that failed I pulled the pump thinking it was the in-tank filters. It was not. I pulled the injectors and could see deposits in the filter baskets, so I sent them off to injector rehab. One was a little clogged according to the charts I got back, and both are 100% now.
The problem turned out to be the o-rings in the fuel pressure regulator. I was only getting 25psi of fuel pressure, not the 50-52 that the bike needs. $4 of o-rings solved the actual problem, that $300 of labor at the local shop could not solve.
Another of life's lessons learned....always start with the cheap and easy solutions.
another hammer rider chiming in and welcoming you aboard. cheers
1 - 7 of 7 Posts
