1 - 1 of 1 Posts
Just an FYI for you folks that relocated your key switch and used the extension harness. The harness that I had gotten did not have the seals around the wires where they go into the plug housings. This has allowed moisture into the connection and caused corrosion. This was making the headlight come on with the switch turned off and would also not allow anything on the dash to power up. Found allot of green fuzz in the connection on the red & orange wire. Part of the sockets had broken off as well. Was able to order the parts needed from Corsa Tech to replace the damaged components. So if you have strange electrical issues and have relocated your key switch the connectors maybe a good place to start looking. May also be worth adding the seals or putting in some RTV to keep it from happening. Easy fix was just a pain tracking it down for the fist time.
1 - 1 of 1 Posts
