1 - 2 of 2 Posts
I'm planning to swap out my stock bars for the Ness Fly Bars on my '05 Kingpin. Using the Witchdoctors no-rise cups. I believe the stock wiring is long enough for these bars when attached externally, but will the stock wires fit if routed internally? I can't find any posts on this. Anyone do this? Thanks!
you're going to have to drill holes and maybe blow chrome off the bars it drill bit catches
you'll need to run each wire thru the bars then out
you'll have to take each wire out of the connector coupler
your going to be down for a good week to get the job done
use all new drill bits old one will not get it
1 - 2 of 2 Posts
